By the way, there are only scenic RX4 2.0 gas in Taiwan. no 1.9dci
(well it's also a problem....
1. the gear box, especially the 5th gear will damage.
(it looks like a manufactured problem )
(BTW, the way to fixed it of the agent of Renault Taiwan is CHANGE A NEW GEAR BOX, about 2500 EUR
2. the spare tire cap fall cause by screw braking
(RFC Taiwan developed a kit to prevent this problem)
(It's serious because you can image that somebody happily driving his/her beautiful, charming RX4 on the high way. When everyone attracted, suddenly, the cap falls...........ouch~)
3.the chink of tail door just between the spare tire housing and door handle
(I'll show you the photo later)
(it looks like a manufactured problem AGAIN)
4.the door of fuel tank brake
(same problem of scenic by fail design of joint point)
5.the spare water tank leakage
(same problem happened in all reanult cars here)
(well.....Taiwan is very hot....)
6.tail window can't rise
(cause by the ....uh....air pressure stick? i donno how to translation that....well u know the stick.......)
These are the major problem we meet here.
