problem with esp
- Gelegenheitssurfer
problem with esp
Hello to all of you and thank you for all your news i have already read in the forum.
I have a problem with ESP.
The signal in control main is not light when i start my car and with the button there is no change if it is open or close
I try to switch off and start again but nothing
My scenic is 2002 model.
Any help ????
Thanks
Any help ????
Thanks
Hello again
I just buy Rx4 the previeus car was scenic 1600
If anyone can tell me how it woks the esp or asr button.
As i read in forum and try to translate from german (with the help of internet)
When the button is green the asr is not working ?
When the speed is more than 60 khm the light is off and asr works ???
Please anyone with more experience
Thanks
Thanks
Family Hotel In Porto Heli
http://www.longview.gr
- Alltagssurfer
I can't understand what do you mean for pityAlex hat geschrieben:The only way for you is to interupt the fuse for the ABS/ASR.
Sometimes when I want to accelerate more quickly,the revolution of engine rise,but the car accelerate slower than other times.Is that the effect of ASR?
Hello Alex
Thanks a lot for your help.
Is there any way to see if it works good the button.
Any example
Thanks
Any example
Thanks
Bobi-BG - on the right side of the steering weel at the botton - is the fuse box - open it and remove the ABS Fuse - start the car - the ABS, handbrake, etc will light up on the dashboard - now you can wheelspin the RX4 - but the ABS wil not work. Afterwards you just replace the fuse - and all is back to normal - tried it a few times - no problems -
Regards
Juriaan
Regards
Juriaan
Hello Alex
I drive it and make some tests
The green light is not switch off after 80 km/h
I have to swich it off.
Is this a problem ?
Thanks a lot
Is this a problem ?
Thanks a lot
