install cruise control
Beitrag von 85755 »
yesterday I installed cruise control with the help of directives steffen.
- for the 4 control keys I used 2 switch Renault Regulator/Limiter - ref. 82.00.002.447 - 29€ / item and them I placed in the 2 empty places under the handbrake
greetings from beautiful Kastoria, Greece
http://int.pixum.com/members/85755_pixu ... 2a9e8da9cf
http://int.pixum.com/members/85755_pixu ... ff5d9f5809
Patlabor
Scenicmodell: noch ein Opel Zafira
Beitrag von Patlabor »
gratulations to your cruise control! Nice to see that this forum is known in so many europead countries!
But your pictures can`t be shown, the destination page only shows the error-message "Sorry. You can not access this album".
Perhaps you can load up the pics directly in this thread?!?
Greetings to Greece
Frank
85755
Beitrag von 85755 »
Steffen
Scenicmodell: Scenic III
Beitrag von Steffen »
Hello 85755,
gratulations - it was a hard job :wink:
Greetings
Steffen
85755
Beitrag von 85755 »
Rafikus
Scenicmodell: Scenic 3 Grand
Motor: 1,6 dci
Ausstattung: Dachreling
Beitrag von Rafikus »
ich kann zwar einigermassen englisch lesen, doch hapert es mit dem Schreiben - sorry.
Was für Taster hatt denn der Kolege für den Tempomaten da unter den Bremsengriff eingebaut? Sind die von Renault, mit den richtigen Symbolen?
Ist es nicht umständlich, da an der Stelle tasten zu müssen?
Gruß,
85755
Beitrag von 85755 »
rafikus
i don't speak german but if I understand rightly the switches are from Renault and the symbols are made from me and stuck on it.
As for the place of switches for me they are functional and i think they is the easiest way for placement and to appear beautifully.
McLach
Scenicmodell: II Ph1 JM
Ausstattung: unbekannt
Beitrag von McLach »
as i discovered during my i bricolage, the "0"-switch does not need any resistor. and the 900 ohm can be a 1k-ohm - cheaper and easier to get.
As rafi said allready: i think that the position U build the switches in ist not very easy to operate. closer to the steering wheel would be much better.
