funktioniert einwandfrei!
SD card mit Fat32 formatieren,dann die dateien auf die Karte kopieren Inhalt von ordner distrib).
in den Ordner Audio die Musik,und Video die Filme.
http://www.tomplayer.net/tomplayer_v0.240b3.zip
wichtig! Audioquelle auf ext. schalten.
Features
- Brand new way to interact thanks to keys (fix carminat joystick and Bluetooth remote controller).
Full details provided below
- Progress bar now displays the current time in a track and the remaining time
- IDtags "title" and "artist" are now displayed instead filename if available
- New screen saver which displays time and GPS informattion (set diapo_enabled=2 in tomplaye.ini to activate it)
- GPS data handling (extract usefull geodetic data from GPS SiRF stream)
- Automatic time settings from received GPS data
- New default skin designed by claudiot88 which provides usefull previous/next icons
- Time is displayed on main menu
- Time can be recalled while playing video
- Default font color has been changed to white in file selector
Bug correction
- The battery icon is no longer mandatory on skins
- The latency before applying sound and video settings on new track has been dimproved
- The bug which was responsible for the volume set to 0 at the begining of the play has been corrected
- The screen saver has been reworked and hopefully the crash on exit may be removed...
- Default paths have been changed for carminat
Known Bug
The total length of a track is wrong
Here is how to interact with tomplayer
Main menu
- Arrow or joystick to navigate among icons.
- BACK to cancel current screen
- MAP for OK on the current screen
- Up left button |__ enables to decrease brightness
- up right button __| enables to increase brightness
Note : Knob can be used to move left/right
There is an exception during file selection :
- knob enables to move up/down among the files
- LEFT/RIGHT enable to scroll a whole screen
To exit this specific mode, press the BACK button and you will navigate as usual...
While playing
-> If menu is hidden (video) or selection is disabled (audio) then :
MENU : Show menu (video) or Enable selection (audio)
BACK : Stop the audio or video and quit to tomplayer menu
UP : Previous track
DOWN : Next track
LEFT : backward
RIGHT : forward
ENTER : pause
|__ : decrease brightness
__| : increase brightness
MAP : Display time
DEST : Mute
REPEAT : volume -
LIGHT : volume +
-> While on the menu (video) or selection enabled (audio)
MENU or BACK : Hide menu (video) or Disable selection (audio)
LEFT : Navigate control
RIGHT : Navigate control
ENTER : Action associated to the selected control
-> While on screen saver :
MENU : to leave screen saver
Note : If screen saver turned on as you you were not in selection mode then all standard shortcuts still apply : UP : Previous track, DOWN : Next track etc...
