Hallo??? Jemand da?
Gerüchte, Fakten, Erfahrungen ...
Hat sich bedankt: 26 Mal
Hallo??? Jemand da?
Seit Tagen ist die Startseite von scenic-forum.de nicht erreichbar... ( Die Unterforen e.g. "Scenic 2" gehen noch... wenn man den Link sich gespeichert hat...)
index.php ->
Fatal error: Uncaught TypeError: mysqli_data_seek(): Argument #2 ($offset) must be of type int, mysqli_result given in /var/www/htdocs/web9/phpbb/db/driver/mysqli.php:288 Stack trace: #0 /var/www/htdocs/web9/phpbb/db/driver/mysqli.php(288): mysqli_data_seek(Object(mysqli_result), Object(mysqli_result)) #1 /var/www/htdocs/web9/phpbb/db/driver/driver.php(381): phpbb\db\driver\mysqli->sql_rowseek(Object(mysqli_result), Object(mysqli_result)) #2 /var/www/htdocs/web9/phpbb/db/driver/factory.php(297): phpbb\db\driver\driver->sql_fetchfield('topic_count', Object(mysqli_result), Object(mysqli_result)) #3 /var/www/htdocs/web9/ext/paybas/recenttopics/core/recenttopics.php(475): phpbb\db\driver\factory->sql_fetchfield('topic_count', Object(mysqli_result)) #4 /var/www/htdocs/web9/ext/paybas/recenttopics/core/recenttopics.php(330): paybas\recenttopics\core\recenttopics->gettopiclist() #5 /var/www/htdocs/web9/ext/paybas/recenttopics/event/listener.php(71): paybas\recenttopics\core\recenttopics->display_recent_topics() #6 /var/www/htdocs/web9/vendor/symfony/event-dispatcher/EventDispatcher.php(214): paybas\recenttopics\event\listener->display_rt(Object(phpbb\event\data), 'core.index_modi...', Object(phpbb\event\dispatcher)) #7 /var/www/htdocs/web9/vendor/symfony/event-dispatcher/EventDispatcher.php(44): Symfony\Component\EventDispatcher\EventDispatcher->doDispatch(Array, 'core.index_modi...', Object(phpbb\event\data)) #8 /var/www/htdocs/web9/phpbb/event/dispatcher.php(62): Symfony\Component\EventDispatcher\EventDispatcher->dispatch('core.index_modi...', Object(phpbb\event\data)) #9 /var/www/htdocs/web9/phpbb/event/dispatcher.php(46): phpbb\event\dispatcher->dispatch('core.index_modi...', Object(phpbb\event\data)) #10 /var/www/htdocs/web9/index.php(244): phpbb\event\dispatcher->trigger_event('core.index_modi...', Array) #11 {main} thrown in /var/www/htdocs/web9/phpbb/db/driver/mysqli.php on line 288
Annonym4000
Scenicmodell: Grand Scenic III TCe
Motor: 1.4L Tce (H4J 700)
Ausstattung: Dynamic
Re: Hallo??? Jemand da?
Beitrag von Annonym4000 »
Das ist echt extrem nervig :(
Annonym4000 hat geschrieben: 27. Jun 2023, 09:06 Das ist echt extrem nervig :(
ein Überlebender!!! 😍
@admins -> Wenn das Forum technische Hilfe braucht (MySQL db, oder die "Improved" Variante :-), PHP, etc. ... BITTE MELDEN!!!
Zurück zu „Scenic 2: Smalltalk“
